February 26, 2026 | Beacon Portal Maintenance Completed
Dear
Valued Client,
We
would like to inform you that the scheduled
maintenance on the Beacon portal, which was conducted on February 24, 2026, from 8:00 PM to 10:00 PM,
has been successfully completed.
If you experience any loading issues while processing claims in the Beacon portal, we kindly suggest clearing your browser cache and making
sure your web browser is up to date.
Clear your browser cache & Ensure your web browser is
always updated
Clearing
your cache helps improve device performance by:
Removes
outdated files that may cause loading problems
Frees up storage
and improves device performance
Ensures you see
the latest version of websites and apps
Helps protect your
privacy
Steps to Clear Cache in Chrome:
- Open Chrome
and click the three-dot menu in
the upper-right corner.
- Go to More
tools > Clear browsing data.
- In the window that appears, select Cached images and files and choose the
time range “All Time.”
- Click Clear data.
Steps to Clear Cache in Edge:
Open Edge and click the three-dot menu in the upper right
corner.
Go to Settings > Privacy,
search, and services.
Under Clear browsing data, click Choose what to clear.
Select Cached images and files and choose a time range.
Click Clear now.
Following
these steps ensures your browser loads the latest system updates and helps prevent login issues or missing data after maintenance.
We appreciate your understanding and cooperation. If
issues persist after clearing your cache, please reach out to our support team
for assistance.
Thank
you for your cooperation.
Best regards,
BizBox Support Team
